61 31 8 361 787 Radiator Fan Switch - 3 Prong - 80/88 degree
$33.95
http://www.bavauto.com//assets/produ...1318361787.jpg
The standard one is Radiator Fan Switch - 3 Prong - 91/99 degree
Part # : 61 31 1 378 073 $ 28.95
http://www.bavauto.com//assets/produ...1311378073.jpg
All pics and prices from
www.bavauto.com under cooling system auxiliary fan.
Well, you have your existing connector and there you can see how the are connected.
Brown with maybe another color = ground
Connections: when ignition is on
Wires jumpered
Violet/grey and brown, fan runs on low speed
Black/grey/yellow OR Black/grey and brown, fan runs on high speed
Yoy can easily test it, pull the plug, use a plier or something other made of metal and jumper ground with one of the others, then the other one, then you know what high and low is, as you can hear the fan noise at low and high.
I do that always to test the functions.
There is no other switch available, and I doubt whether it is recommendable to have a switch already kick in at 75 degree C.
The engine NEEDS a certain operating temperature, otherwise you will have more wear and higher fuel consumption if the MOTRONIC always 'thinks' that engine is still cold.
