Also: http://www.bimmer.info/forum/showthr...ght=wiper+hoodI believe the problem can be caused by worn wiper spindle bushes or linkages. There is practically no margin for error with any slackness in the wiper mechanism at all. A common E34 problem is the lower part of the arm (not the blade) hitting the hood instead. I tried moving my wiper arm around 1 spline to prevent the arm from hitting the hood but wound up with it hitting the top-side of the windshield just like yours. As you can see there is not any real leeway to position the wiper arm by rotating even one spline without causing problems elsewhere.
