Results 1 to 10 of 17
Thread: OEM brake rotors & pads - which brands ?
    Aug 2004
    Regional NSW, Australia
    Default OEM brake rotors & pads - which brands ?
    Have searched but haven't yet found.
    What brand are BMW rotors and pads ?
    I believe that pads are made by Jurid but have no idea about the rotors.
    Are E39 & E36 the same as E34 ?
    "I'm not the village idiot.
    e36 pads are the same size as e34 pads at the front. I don't know about the rear. I think BMW rotors brand are Balo, not certain though.
    Aug 2004
    Quote Originally Posted by Zeuk in Oz
    Bump.
    Anyone know who makes BMW brake rotors ?
    ATE brake discs and Jurid and/or ATE pads.
    What you get from the aftermarket is also ATE but a different quality, (I have read/heard/maybe rumours)
    http://www.conti-online.com/generato...ge_ate_en.html
    Lexington, Kentucky
    I put ATE rotors and Raybestos QS on the front about 25,000 miles ago. I have a lot of vibration when I first put the brakes on lightly. Seems like the rotors are warped. May try to turn this weekend.
    Australia
    I thought that they used textar or ate for rotors. I've used Textar rotors and raybestos pads and the setup works very well.
    Aug 2004
    Thanks Erich, thanks guys.
    That more or less confirmed what my mechanic was saying - stick to genuine rotors & pads. I think i will heed his advice.
    minneapolis
    I had a mechanic tell me that he always gets his rotors turned before install...
    even when new
    This might be a good idea for any aftermarket rotors. saves having to do it later anyway
    nate
    Hey, I have a set of BMW rotors for your car. They should not be hard to get.
    Stock are VERY different to OE, they have grooved surfaces, roundels and part numbers stamped into them. OE are smooth and need a good clean before using if you want to avoid the squeaks. Very ferw people do this, but if one searches around you will find some real purists that have very exotic procedures. Nick
    Wichita, KS
    If new rotors have to be turned before being installed to make them true, they are junk to begin with.
    May the Schwarz be with you...
  1. Need to replace rotors WITH brake pads together?
    By Dathaeus in forum 3 Series BMW
    Last Post: 09-28-2008, 10:01 PM
  2. Changing brake pads and rotors in your BMW
    By shogun in forum 3 Series BMW
    Last Post: 07-14-2006, 03:01 AM
  3. new brake pads and rotors
    By nuwde in forum 5 Series BMW
    Last Post: 07-30-2004, 10:32 PM
  4. Replace Front Brake Pads without rotors...
    Last Post: 05-27-2004, 02:48 PM
  5. Brake Linings Msg... Pads/Rotors Are Ok.. What???
    By DaCan23 in forum 5 Series BMW
    Last Post: 03-12-2004, 01:50 PM
