Results 1 to 10 of 16
Thread: Want to Lower Touring
    Feb 2007
    Minneapolis, MN
    Default Want to Lower Touring
    Okay all you touring owners...I've looked everywhere and still can't find the answer. I want to lower my touring 1" IN THE FRONT ONLY! The Bently shows how to lower the rear by adjusting the auto-leveling suspension. Every spring kit I've seen is for 4 springs. I even emailed Yyves @ BMA and he wanted to sell me the Sachs kit. I don't wnt to spend $700.00 and throw away half of the parts!
    Anyone out there lower their touring? Please let me know how.
    Buy the sachs kit, install the fronts and keep the rears for when your LAD fails.
    I ordered mine last week. Patrick had one kit left after I bought mine (at that point).
    Feb 2007
    Minneapolis, MN
    Yeah Kal...so far that's the the best solution I've seen, but I haven't read anything good about deleting the LAD which I presume one would have to do in order to use the Sachs stuff. Besides the PO was nice enought to have the hydrolics replaced about 10,000 miles ago. :-)
    Aug 2006
    Durham, NC
    If you only need a 1" drop, order a set of M-Tech front springs from your favorite supplier of BMW parts (on-line or otherwise.)
    Here's a link to an article on these: http://www.bmwe34.net/e34main/mainte...uspensions.htm
    This way you have two options when you do the rears. Option 1: get M-Tech springs for the SLS Rear or Option 2: Get M-Tech springs for the non-SLS Rear.
    Here's the part number for your car:
    BMW Technic Front Spring Assembly 31 33 1 138 810
    If you want to make it a bit lower, use the 3mm upper front pads, instead of the 9mm stock pads. (Note: These numbers are from the M5 parts list):
    FRONT SPRING PAD UPPER 3mm 31 33 1 128 523
    The springs cost me $111.00 each the pads were like $4.00 from Maximilian Imports.
    Here's some photos for reference:
    Front before an after:
    Front with Style 32's installed:
    On my car the most of the SLS System was leaking or trashed so deleting the SLS was the only option. I really didn't want to do it.
    Fortunately, the M-Tech springs combined with Bilstein HD's came out great and the car handles better than it ever did. I've got about 1000 miles on the setup so far and no regrets.
    Or just go to the dealer and order the front M-tech springs.
    Right, I agree -- I've driven a lot of cars (usually with bilsteins and "sport" springs that were sold to an unsuspecting owner) that have had LAD deletes and they've all been pretty bad. LAD is great.
    I've always liked the sachs kit in my 535. The car handles amazingly well with uprated sways, it's predictable and it's comfortable for a sport suspension. Better yet, you can align the car and have it stay in spec because the kit is matched to the chassis. LAD parts are expensive. I just warrantied a shock -- the lady that owned the car prior to me had a garage replace one and it blew out again (between you and me, they installed it incorrectly). She paid $900+ for one shock, I was invoiced $700 for the part (covered by warranty, of course).
    Were I faced with the decision of replacing them out of pocket, I'm not sure that it would be worth it given the sachs kit option, and the availability of factory non-LAD touring parts -- '94/'95 don't have self leveling. I know of only one person who's installed the sachs kit on a touring, and I haven't heard his impressions of it yet.
    I'm going to try it out and see what I think of it. My only real concern is weight bias and keeping the headlights level with a lot of weight on the rear axle, which is the entire purpose of LAD.
    Nov 2006
    Quote Originally Posted by Kalevera
    Err...
    I deleted the LAD and installed B&G Touring-specific springs with Bilstien HD's and the ride is nothing short of fantastic... And I have 18's with 40-series tires. No, I'm not a kid that thinks a harsh ride is cool. I'm a 35 y/o dude who crushed my spine a few years ago in an accident - so a smooth ride is pretty much essential to my existence.
    It all depends on the components you use. Crappy, cheap springs will perform as such.
    Car Info is HERE
    Austin
    I just renewed my LAD with new accumulators and the valve bits and I am good as new for another 100k. Good as new and as designed....no heavy thinking, nothing to debate....worth the money and without the headache.
    Connecticut
    Quote Originally Posted by shrike071
    Err...
    Who supplies the B&G springs? Are they a stiffer spring then stock? How much do they lower the car? The M-Tech springs that BMA is supplying for the Touring are the same ones I bought for my 535i. I'm sure these would be fine for the front but I have to wonder about the rear springs & how they would handle the extra weight of the touring.
    90 535im
    02 R1100S, 87 R100S
    76 R90/S,73 R75/5
    Alfa Romeos- 65 Giulia Spider Veloce
    & 66 Duetto 1600 Spider
    El Paso TX
    IF you are worried about the headlights under load with an SLS Delete, you could always install Hella Smileys WITH adjuster motors and adjuster switch... works great.
  1. Audi a6 touring v series 5 touring
    By johnnyturbo2002 in forum 5 Series BMW
    Last Post: 10-18-2006, 04:04 AM
  2. OT: low, lower,......
    Last Post: 10-11-2005, 01:15 AM
  3. how low should i lower my e34
    By saty in forum 5 Series BMW
    Last Post: 06-19-2004, 10:26 PM
  4. lower my 525?
    By FLYNSHU in forum 5 Series BMW
    Last Post: 04-19-2004, 10:25 AM
