Results 1 to 4 of 4
Thread: Valve cover gasket..Dry or with sealant?
    Jan 2007
    Dayton Ohio
    Default Valve cover gasket..Dry or with sealant?
    Do you use a sealant on the valve cover gasket? Or do you install it dry?
    Maryland
    I used sealant on the cover side but nothing on the head
    dry, maybe a dab of snot at transitions to seal the crack
    I installed mine dry and haven't had leakage at the VC edges. One of the front nuts started seeping recently though. Hopefully tightening it up will solve the problem. HTH
  1. valve cover gasket
    By wolfpack in forum 5 Series BMW
    Last Post: 02-24-2008, 04:33 PM
  2. Re-use valve cover gasket?
    By bsell in forum 5 Series BMW
    Last Post: 02-03-2008, 01:40 PM
  3. valve cover gasket
    By darron525 in forum 5 Series BMW
    Last Post: 04-09-2007, 07:22 PM
  4. Help! Doing Valve Cover Gasket
    Last Post: 08-26-2006, 11:50 AM
  5. Valve Cover Gasket
    By Shaun in forum 5 Series BMW
    Last Post: 03-12-2004, 01:09 PM
