I have yet to see a cel light on my car and it still won't perform the stomp test? Where is the cel light located exactly?
I stomped so many times last night my ankle is sore!
Thank you
Fred/Houston
Thank you
Fred/Houston
...oopsOriginally Posted by Fred/Houston
94" E34 540ia
Tnx
Fred/Houston
CEL light is located in the lower left corner of your instrument cluster. It simply says Check Engine. The Foglight indicator is right next to it. Some cars may not respond to the CEL diagnostic procedure (this is what I've gathered from this forum). Another possibility is that the light is missing all together.
I do not know on the 540 but my old m20 did this trick. The TPS was dead and that is what triggers the code from the stomp test.
I pulled the connection and used a jumper to get the ecu to go into the diagnostic mode.
89 525, 86 jetta diesel, 07 wrx with mods, 06 commander
1 mean wife, 2 daughters, 1 bull mastiff. At least the jetta
is cheap to keep up.
Then my light is definatly out. I'll have to look in my Bentlys when I get home to see what Tps means.Originally Posted by ajt3nc
Fred/Houston
TPS means Throttle Position Sensor, a switch or potentiometer (depending on the engine) that advises the engine computer of the throttle position.
1997 535i V8
Fred, as stated in posts above...your car's CEL (Check Enging Light) is located on the left side of the instrument cluster (if you have an owners manual it may help you find it location since it's identified in the book).
And the CEL should illuminated anytime you turn the ignition to postion 2. If it does illuminate, then you just need to recheck the procedures for the STOMP test...many people have your same experience in having difficulty doing it...if it does NOT illuminate...then something else is wrong...like the bulb may be removed or covered up etc...
Q
95 525iT / 97 740iL
Check the bulb if it doesn't come on with the ignition.
Bellevue WA
86 Porsche 951 - Track Toy
