T stat ought to keep the temp up. Sounds like a lazy one, cheap replacement if in doubt.
So I was doing 160km/hr (100mph) tonight -- it's 3:42AM local time here and it was about 8 deg C (46 deg F) ambient temp according to the OBC, when I noticed that the temperature gauge on my dash board was actually dropping.
Usually the needle is a hair-width's away from the middle notch, but tonight it dropped a fair bit to the left, past the notch between stone cold and middle.
I found this quite odd, does this make sense to anyone at all?
ditto, replace it with a BMW stat available at your favorite online sources.Originally Posted by Ross
T stats come in several temps 90, 88, etc.
and local shop tried to sell me a 72 for my M50tu...eeeh Wrong!
Bad t-stat, my 540i ran just above blue the whole way back from Oregon. Swapped a fresh one in, and it sits at the middle all day.
Yep... bad thermostat...
OK thanks for your replies guys. Looks like I'll be writing an email to Patrick from BMA![]()
i would consider this normal. i do this quite often and the needle ussually drops just a fraction at higher speeds. makes sence to me.
My thermostat used to be really sluggish, especially in cold weather, causing the engine to run cooler for long periods of time. I installed a new one and the engine heated up much more quickly. One other thing i noticed was that with the new thermostat, the final temperature is about a needles width right of center rather than exactly at center where is was before.
OK well this has thrown a spanner in the works! (Haven't emailed Patrick yet). I noticed that my needle is fine now, it only did it at (really) high speed. It's not often that I drive so fast anyway.Originally Posted by mattyb
If the replacement is cheap and easy to do, I might as well do it. How are you supposed to know what t-stat you need though, since there are so many? I had followed a little bit the "controversy" surrounding installing a different t-stat to what the factory put in your car and it does this and that for your engine which supposedly improves something, however I am not interested in this and just want to maybe replace the t-stat with the same spec as what was installed originally in the car.
