Keep trying... I had same problem until it start spitting out flashes.
Hi,
I have a 1994 540ia and it will not give me any reading when I do the stomp test. I know how to do it after having owned an E32, but I also read that if the phone is disconnected it won't work.
I know probably none of you even use the phone or even have it installed still, so what can the problem be?
Thanx
Fred/Houston
Once you turn on the key to position II, you have to hit the acc paddle 5 times very quickly. The key is to start to first hit as soon as the lights on the dash come on.
I do this all the time. It should not be related to the phone.
94' AlpineWhite 530i, 5 spd Auto, 112K miles, Mfg in 4/93
Ok, I'll get more persistant with it and see if I have any luck.
Fred/Houston
...another E34 musician![]()
do you have CEL? I wanted to do that stomp test but dont have CEL![]()
HID 5000k low 3000k fogs
dynaudio seps. mc intosh amp
Race logic TractionControl
When I did it I followed all the instructions on the boards and couldn't get it to work. What finally worked was I turned the key to position 2, waited for the seatbelt sign to time out on the dash and then pumped the accelerator 10 times. Worked perfect every time. IIRC.
could you please provide a link to the procedure? Thank you.
Sorry but I don't know what cel is? I tried again last night in postion 2 and still no luck. I will wait for the seatbelt warning to turn off tonight and try again.
Fred/Houston
Check Engine LightOriginally Posted by Fred/Houston
1997 535i V8
Dang! I don't remember ever seeing a check engine light? I'll check tonight and probably be moaning for cures in the morning.Originally Posted by DaveVoorhis
Fred/Houston
