Results 1 to 7 of 7
Thread: Curious - about rear dropping from Neut - Drive.
    Aug 2005
    West Portland, OR
    Default Curious - about rear dropping from Neut - Drive.
    I've got an auto, and I've always been curious as to what EXACTLY causes the rear to drop when you put the car in drive from neutral or park as well I believe.
    EuroLux:. Private Detail
    El Paso TX
    torque
    Aug 2005
    West Portland, OR
    This is while standing still, no movement besides a running engine with foot on the brake - shifting from N -> D.
    Just idle torque?
    Quote Originally Posted by CharlesAFerg
    Just idle torque?
    yes, but the gear is engaged.
    Adelaide, Australia
    if u give it a tiny bit of throttle is squats more, and then you look tough!
    :P
    11/88 535iA
    Dec 2006
    Melbourne, Australia
    Quote Originally Posted by Michael999
    :P
    Quoted for truth (and tuffness )
    The reason it happens is because when you switch into gear, the transmission begins transmitting torque through the drivetrain in the rear. This happens while your rear brakes are clamping down and not allowing the wheels to rotate. The torque goes through the halfshafts and because they are physically locked on the outter ends, the differential and rear subframe try to rotate. This causes the rear end to squat down.
  1. Replies: 6
    Last Post: 03-12-2009, 12:11 AM
  2. E30 drive train rear U-joint change - DIY
    By shogun in forum 3 Series BMW
    Last Post: 04-13-2006, 07:26 AM
  3. '89 525a stalls on shift to neut. or AC to Off
    Last Post: 04-12-2006, 06:10 PM
  4. Dropping like a rock!...Coincidence??
    By Brian C. in forum 5 Series BMW
    Last Post: 10-31-2005, 10:53 PM
  5. Dropping the new head in
    By Andrew in forum 5 Series BMW
    Last Post: 07-02-2005, 09:19 PM
