Hi Bill...know your 944's?
Visualize the transaxle, where the shifter linkage bar connects.
...killed the threads where the shifter linkage bar connects to the transaxle selector. The linkage bar has a bolt that pins the bar to the transaxle selector. That bolt sheered and I had to drill it out.
The linkage bar is steel. The drill out killed the hole so I think I will need to dill an oversize hole, tap it and sleeve it. Depth of the sleeve is likely ~ 3/8s of an inch.
Good news is that with the tranny out there's a fair amount of room to work.
I'll poke around on the Keenserts and Timeserts.
Originally Posted by
Bill R.
It depends on which threads you killed....as to whether the helicoil is the best solution. There's about a zillion other solutions depending on where the damaged thread is... Besides helicoils lookup keenserts and timeserts etc etc.
Bellevue WA
86 Porsche 951 - Track Toy
