Results 1 to 10 of 10
Thread: tilting car jack-ideal for under car work?
    Default tilting car jack-ideal for under car work?
    I found this on the German forum, somebody just made the first trial with that
    http://s71.photobucket.com/albums/i1...agenheber2.jpg
    http://s71.photobucket.com/albums/i1...agenheber4.jpg
    http://s71.photobucket.com/albums/i1...agenheber3.jpg
    Who has it? And what experience? And where to buy? Do not know if that is the correct English word for that jack, in German they call it Kippwagenheber.
    According to the info on the forum, only the battery has to be removed, all fluids can stay in the car. He said nothing leaked, except he sealed the window washer tank, because that started leaking washwater.
    Jeez.... saw this long ago... You know, you got lots of fluids to worry about when you do that... battery acid for one... oil, washer fluid, tranny fluid and who knows what else can leak...
    USA
    that looks like an extremely bad idea!
    Default The Vehicle Tilter
    Found it
    http://www.eastwoodco.com/jump.jsp?i...rID=142&KICKER
    actually it is made in Germany :
    http://www.liqui-technik.com/kipp1_e.html
    http://www.liqui-technik.com/kipp2_e.html
    Actually it seems to work quite well. Here a comment by Shayne on Bimmerboard:
    I have seen these. While it may look close to the ground there is actually about 30 cm between the body and the ground.
    No worries about fluids unless your engine is weak. I've had vehicles on the side and roof a number of times and fired them up without incident.
    I wouldn't run it in that position but for service, even extended service, I wouldn't be concerned.
    Shayne
    525iTA
    533i
    735iL
    FAQ:
    http://www.eastwoodco.com/jump.jsp?i...8&iSubCat=1173
    Honolulu
    Default Eastwood sells this
    looks dangerous.
    put a six pack of beer under it and run a wire from the support arm..... and you got a man trap.
    Hobart, Tasmania, Australia
    I agree with Tiger... in regard to the fluid leakage worries.
    Gone but NEVER forgotten. :'(
    And then...
    Oldham, England
    Saw this idea on TV in the 60's so its been around for a long time. Some old boy used it to tip a Rolls Royce on its side. If you want to get underneath that badly you probably wouldnt mind draining the oil but I hope HIS engine and tranny mounts are sound:-)
    Aug 2006
    Durham, NC
    It works for my lawnmower....
    Do you think you do clutch work with it? It doesn't seem to be that would be so. For the price of the thing, I rather spend a few bucks more and get a two or four post lift. Of course, it takes more space and isn't portable...
    It's probably great when it comes time to polish your roof.
    Oldham, England
    Quote Originally Posted by BimmerMeUp
    Dont want to be an anorak, but you can get a single phase scissor lift that is portable. Well.. you cant actually carry it but you can drag it about on wheels. Nussbaum in Germany used to make one
    Nov 2004
    Gateshead,UK
    My friend bought one of those so he could rebuild his Morris Minor, and that was way back in the early 90's. It simply bolted on the hubs and then you swung the shell over. Simple. They're a great tool for light cars, but I would be a bit nervous about putting something as heavy as a complete E34 on it - just in case it rolls too far, or some suspension components break.
    HTH,
    Shaun M
  1. @ Bill R. : your ideal tool set for BMW
    Last Post: 02-09-2009, 08:53 PM
  2. Replies: 3
    Last Post: 12-09-2006, 10:12 PM
  3. Ideal E34!
    Last Post: 04-23-2006, 11:47 PM
  4. Tilting engine?
    Last Post: 03-01-2006, 01:19 PM
  5. Jack and Jack Stand Positions...
    By dternst in forum 5 Series BMW
    Last Post: 02-08-2005, 01:54 PM
