Dave, if you start the car the voltage should at least be up to 14volt so that should answer your question. Otherwise I have no freakin clue.
Finally wired up my HID kid (Mcculloch 6000K) and neither low beam light. I found thisrelatively recent thread kicking around and a minimum voltage of ~12.5 is mentioned. I tested voltage at the stock connector and found ~10,5. Voltage at the batt (engine off) is less than 12V as the car has been sitting most of the winter and only periodically started.
So, am I hinting at the obvious. Will a voltage of 10.5 at the low beam fail to light these suckers? Its too odd that both won't even flicker. I'll be taking it for its maiden 2007 voyage on Saturday, so after that I'll try it again with a fully charged batt.
Hopefully it works,
Dave
*RIP Oskar the DOG*
Did you check your fuse... The lower your voltage, the more amperage the ballasts draw so it will blow your fuse. Higher voltage will draw less amperage.
try starting your car first then turn the hid's on..had a drain batt.last year and turned on the lights it just flickered then shuts offOriginally Posted by Dave M
HID 5000k low 3000k fogs
dynaudio seps. mc intosh amp
Race logic TractionControl
Also replace 7.5A fuses with 15A fuses.
Thanks guys. I didn't want to start the car last night for just a few minutes as its been sitting for a while, needs an oil change etc........
It'll be started tomorrow and I'll reoprt back.
Dave
*RIP Oskar the DOG*
