Hello everyone. Has anybody here tried to test or replace an ABS sensor? I think I have a problem with one - the ABS light comes on and then goes out as it should but then comes on once the car begins to move forwards.
Yesterday I tried (without success) to take one of the sensors out to clean and check it. Is that a hex allen bolt that holds them in? Is it possible to do a continuity check on them with a meter? Bentley says clean the lens - has anyone here suceeded in getting one out and replacing it - and how did you know which one out if the four to change?
Many thanks for any advice you can give.
Simon Daubeney, York, England
1989 530i SE M30 engine,\5 spd 152,000 miles.
