If you do a search, you would have found this:
http://www.bbesound.com/bmw/hidinstall/
I have not read a definative answer around how to fix the "low beam" warning that comes up with some HID installs. My HID's work fine I just have the factory plug going into the ballast and then the ballast to the bulb. They do work fine but I have the "low beam" warning on all the time? Anyway around this?
Thanks,.
norelays needed!
just wire in a small bulb (like a sidemarker bulb) in parallel to each bulb, problem solved!
Either get a newer kit that addresses the check (most new ones do), or just wire a bulb inline. That's the least hassle. Else, go relay.
meh, the LOW BEAM warning comes up occasionally for me, small price to pay for HIDs
'90 535i
UUC SSK, Bilstein shocks, Eibach spings, EAT chip, CAI, Super Sprint exhaust, Hella euro headlights, HID kit, M5 spoiler
i just always run them, there good for drl's and makes people see you easier..its just a habit for me to turn them on as i get seated in the car
Originally Posted by Guelphguy
click on this site...might helphttp://www.bbesound.com/bmw/HIDinstall/
HID 5000k low 3000k fogs
dynaudio seps. mc intosh amp
Race logic TractionControl
Just installed 3000k HIDs in fogs... no warning unless I unplug one of the ballasts or bulbs.
if you unplug the ballast of your fogs hid theres a warning?Originally Posted by Qube
Yes, I unplugged one bulb... warning.Originally Posted by bmwrp8
Unplug one ballast... warning.
This is the same behaviour with low beams.
Low beams are Kaixen. Fogs are Decante (Germany).
