1. Is it possible to stop the common rust issue for these cars that happens at the bottom of the doors?
If there is "bubbles" under the paint, it doesn't mean tha tit hasn't "broke through yet" - it means its RIGHT under the paint. That's rusted through bro. Only a matter of time before the paint no longer adheres to the material and you're looking at brown love.
2. Any thoughts on the thin horizontal strip of trim on the front doors being bent away from the car slightly?
Well, you say that both doors have weird trim going on, rust, and there is wind noise. This vehicle may have been in an accident nvolving the doors. I would really look at the carfax.
3. How much could it cost to re-align the drivers side power window that seems to be off track? Could this also be the cause of hearing a slight bit of wind coming through at highway speeds?
Forget cost you can look at it yourself. It is probably the window "sticking" in the rails below the door. Again, if this is happening, consider that maybe something was bent there... ie. and accident?
4. Am I being paranoid that the washer fluid being not filled could mean that the previous owner didn't care for it meticulously?
I don't even have a resevoir! I wouldn't hold this too high on the list of concerns. Pull the dipstick and look at the oil. Truth is its REALLY HARD to not maintain these cars. Simple oil change every 3000 - 4000 miles and that's that.
5. What about an abrasion on the front corner of the engine cover from where it rubbed up against the padding on the underside of the hood? Common or fishy?
If you mean the hood mat is a little depressed/rubbed on at the front timing chain cover, that is normal.
6. The guy that showed me the car hadn't ran a carfax on it and didn't know a whole lot about the history. Carfax.com tells me the car has 7 records but if someone could look up the vin (WBAHD5320SGB37144) I'd really appreciate it--have no idea what the 7 records are.
Sounds like maybe he didn't want to know or didn't want you to know
. Check it out.
Thanks guys! I'm trying to decide if I want to get serious about the car and have it inspected and wanted to give you an account of what I saw at a glance. Also, any further thoughts on this cars age/mileage/price etc. in terms of it being a rock soild daily driver would be appreciated also.
Thanks and have a great weekend.
