bump
thanks!![/quote]
alright so i picked up another starter, scrap said it's for a 90 525ia
but again i don't seem to have a connector for 30h
can someone please take a pick if you have an automatic 1990 525i m20, i need to see how the wiring is, and i'm pretty sure that a main wire has been cut (from alternator to starter), all i have is a 4 guage wire going directly to the battery (battery is in engine bay), a yellow/black wire and green/black wire
pics please!!
thanks!!
bump
thanks!![/quote]
Yellow/black and green/black can both be connected together at the solenoid connector (the smaller one of the two you can see). That's how mine is. It works perfectly.
HTH,
Shaun M
Hey thanks!!, hopefully that'll work, i'll be installing the starter tommorow then
just one more question, is there 1 or 2 wires coming off of the the main terminal(battery / alternator, or just battery)
thanks
bump!!
Do you mean the big terminal on the alternator? IIRC there's the big cable that comes from the battery, and a little flexible tail from the starter solenoid that also goes there. Push both leads on the bolt, tighten the locknut over the top and she's good to go!
HTH,
Shaun M
yeah that's what i thought, the po had cut the alternator wire
alright now only if it were to stop snowing i could work on my car, sigh
thanks for all your help!!
