Originally Posted by
535ise
Which M5 TB's, E28 or E34 ? Diameter of the throttles ? Which type of ECU and cam are you using ?
How are you mounting them to the head ?
...a friend who is more dedicated to seeing the project done had them off me for his E30 335 turbo.
... a PITA in other words.
Good luck with the project, i hope it goes well for you.
Right now I'm still in the planning stage so I may decide it's indeed too much work, but I've got some e34 M5 (S38B36) throttle bodies on the way from Germany, (assuming the seller keeps up his end of the bargain.) I'll use the same ECU and some sort of alternative to the AFM, like a MAP or MAF. Idle control should be pretty much the same, as should TPS. Clearing them in there and mounting it up is where the costs come in, and my plan is to saw off the last inch of the stock manifold, saw off the last inch of the TB's, and weld them together. That way I keep the bolt pattern and injector geometry to match the head. Now will that really work? I have to get the parts in hand to really see.
I've seen the thread on the e30 board, that is an impressive setup. Hopefully the air box won't need a hunk cut out for the e34!
The head I'm still building up, and I plan to get a Schrick 284 cam from VAC and keep it otherwise stock. It's been CNC ported by Bavarian Engine Exchange and it looks pretty well done, but I am by no means an expert. I may totally screw up the whole engine and have less power than stock but it's worth a shot just for the gleaming TB's under the hood. The headers have the same plan, I've got s38B36 headers and will lop off the last inch and weld on a flange that matches the M30 head, then fab a piece to make the bottom bolt on to the rest of the exhaust.
The MAF/MAP should allow me to get the mixture right, and if I want to play with timing that's another $500 or so for a programmable ECU... I'll wait on that until the beast proves it can make it down the block!
Robin
72 Chevy K10
01 E39 M5
