I hear a "clunk" on the front right wheel when this wheel pass from the street to my drive way (small level difference). Ball joints, trust arm bushing and other element of the front suspension checked OK.
In the E34web site they give the following hint as a possible cause of this "clunk":
"Loose strut housing nut
If you changed your shocks, you may have a loose strut nut. Take a monkey wrench a tighten it. You don't need to remove the shock assembly, just jack up the side."
But i don't understand what they meant exactly, what is this strut nut that seems so easily accessible ? where is it located exactly ? Could you shed some light on this for me please ?
