Results 1 to 4 of 4
Thread: m50 cranks but wont start
    NYC
    Default m50 cranks but wont start
    I have a 91 525 with the m50 engine.. The car carnks but wont start. The car was running fine on my way home from work one night and would not start the next morning. I cahnged the Fusible Link figured it wasnt getting spark or fuel.. Didnt work, next I chnged the fuel pump.. Didnt work, I swapped the dme with a spare I had.. Didnt work.. I changed the spark plugs and crank position sensor.. I have to look at it again but the sensor is close to touching the teeth.. I am pretty sure it isnt, anyhow Didnt work but now it feels like a car struggling to start with a bad distributor.. The coils and boots and plugs are fairly new and purchased from the dealership.. I checked the relays and fuses nothing seems blown or burnt.. Does anyone have suggestions?
    Nov 2006
    Did you check the ground by the hook used to remove the engine? If the ground wire is broken there your car will not start.
    1992 525i Touring M50 5spd Manual 230k+ miles - SOLD:-(
    David, you've already tried a few things, but did you:
    Check for strong spark?
    Test the fuel pressure?
    Replace the fuel pressure regulator?
    Check the poiwer supply to the sending unit at the fuel pump?
    I was tracking a siminar problem a while agao and found it to be a corroded wire at the fuel pump sending unit (easy fix). I just tried to find the old thread, but couldn't. I'll add the link if I find it. Although the relays (DME and Fuel Pump) look 'OK', they may be bad. Assuming you spent money on the fuel pump, plugs, CPS etc., you've blown quite a bit on this issue already, so you may want to try starting with some basic stuff like the spark and fuel pressure checks.
    Good luck,
    Dave
  1. Car cranks but won't start - Ideas??
    By Adnan in forum 5 Series BMW
    Last Post: 07-26-2007, 08:51 AM
  2. Engine Cranks, Won't Start, Trans Program
    By jimross in forum 5 Series BMW
    Last Post: 08-19-2006, 11:06 PM
  3. 1993 520i cranks but won't start
    By gigiscott in forum 5 Series BMW
    Last Post: 01-20-2006, 07:19 AM
  4. 1992 535i TAKES THREE CRANKS TO START WHEN HOT
    By kristyrick in forum 5 Series BMW
    Last Post: 07-14-2004, 10:41 PM
  5. 530i 94 cranks but won't start
    Last Post: 06-04-2004, 11:15 PM
