Results 1 to 10 of 11
Thread: Fuel Injector Wiring Harness
    Mar 2004
    Default Fuel Injector Wiring Harness
    Anyone know where I can get the wire harness for the fuel injectors? I checked at bmaparts and partsbmw and didn't see a listing for the fuel injector harness.
    The problem is the 5th and 6th cylinders don't seem to be firing and so far I have isolated it to be an electrical problem with the 5th and 6th fuel injectors. When I checked it out with a stethescope I don't anything hear anything from the solenoid in the 5th injector and just a faint trace in the 6th injector. So I think it might be that the wires are bad going to the 5th and 6th fuel injectors.
    So if anyone knows where I can pick one up I would appreciate it.
    thanks,
    Brian
    baton rouge, loserana
    in a e34 535 that's the whole engine wiring harness, it should be real easy to diagnose, that is a semi sequencial injection system, it fires 3 cylinders at a time 123 then 456, you will have a constant 12 volts with the key on to one side and the computer pulses the ground on the other side, if you only unplug one injector and go probing with a test light you will see 12v on both sides
    Default Close Winfred, it opens 1,3,5 and then 2,4 6 at the same time...
    Default Since its number 5 and 6 are you sure you don't have a blown head gasket between
    and did you check the compression also?
    Quote Originally Posted by jbw535i
    thanks,
    Brian
    i am allowed a screw up once in a while, it's been a long day, and i had to give up my big ass jeep
    Default No jeep?
    i figured to get it the way id want it i would spend about the next 3 years worth of fun money, no new guns, big tools, home theator equipment, piss on that ill go back to my orignal truck plan, 67-72 LWB c10 chevy pick up, just missed out on a 55 chevy pu for a few hunderd friday, love the body style hate the suspension, but that's why they invented the 4 link and mustang II front end
    bottom line i can build a 2wd rod a lot cheeper then a 4wd creeper
    Default Lots of 67-72 running around here....rust free... lowrided..
    i am thinking squashed late model vette or redneck mobile for a injected motor 6 speed and discs all around, 4 link and coilovers in the rear (bags are over done, and i don't like the got stuck on a cigerette butt stance)
  1. removing injector harness on M60
    By bbig119 in forum 5 Series BMW
    Last Post: 12-22-2006, 12:25 PM
  2. 535i Fuel injection wiring harness removal
    Last Post: 08-07-2006, 11:39 PM
  3. Injector Harness
    By stargazer_61 in forum 5 Series BMW
    Last Post: 12-26-2005, 03:02 AM
  4. Is the part # for wiring harness
    By Elekta in forum 5 Series BMW
    Last Post: 02-17-2004, 05:07 PM
