you dont need 3mm spring pads with the Eibachs, the drop is PERFECT.
i am running Eibach/Bilstein HD and the ride is indeed harsh, but the car handles like its on rails, and thats with my crappy stock wheel/tire combo!
of course the swaybars help tremendously, so dont forget those, and do indeed get new shocks while you replacing everything else.
3mm spring pads might make bumps a bit shakier, and if you have rough roads, stick to stock, but be sure to order new ones.
