How did you adjust the steering box? Was told I needed the same.Originally Posted by mikeythekidd
TIA
My steering feels pretty loose for a BMW. It tends to wander and requires constant vigilance. Certainly nothing like my E90.
Here's What's Been Done:
Tire pressure checked
Steering box adjusted
Tie-rod ends replaced
Lower control arms
Front thrust arms and bushes
Wheel alignment
What did I forget?
TIA
Nice site. Thanks
I replaced my idler arm yesterday, and that seems to have helped tighten things a bit. I think tread design could also cause you to use "constant vigilence"... my summer tires require more of that than my winter ones.
_
My Indy improved things by adjusting the steering box and by swapping the front and rear tyres. The front ones had been wearing mostly on the inside edge and were, exaggerating a bit, conical. Swapping might help you too.
