Check the refrigerant charge. Perhaps a little under and the evaporator is freezing.
does anyone have the same problem as mine?ok here it goes Just changed my AC compressor ,expansion valve and the drier filter and now my AC is colder than ever!the compressor shuts off for awhile if the interior is cold enough then turns back on when its getting warm like it should, but sometimes the AC compressor doesent turn on after in shuts off. what ill do is I have to turn the AC off wait for awhile and voila its back but if its cold it shuts itself off again then id do the same thing again...please help I checked for high pressure in the system, all normal. changed the pressure switch, still the same.I'm thinking of putting a manual aircon thermostat but having second thoughts...please help thanks in advance
HID 5000k low 3000k fogs
dynaudio seps. mc intosh amp
Race logic TractionControl
checked it already refrigerant is normal and evap.is not freezing..still after awhile compressor doesent turn back on.anymore ideas??
