Results 1 to 4 of 4
Thread: Engine warm = Fast idle, what's at fault here?
    Default Engine warm = Fast idle, what's at fault here?
    I know idle issues have been covered ad nauseum and I've done a bunch of searching, so sorry to bring this up! Now that it's been getting a bit warmer in Cleveland, I noticed that my car idles at ~1000 rpm when it gets warmed up. I used the Bentley and the results were:
    -TPS voltages check ok
    -AFM resistance changes when the "flap" is moved (but not linearly, it kind of jumps around)
    -ICV hums when on and 1-3 pin resistance measures ~ 4 ohms high.
    I cleaned the ICV to ensure that it's not sticking and the engine idles perfectly when cold. So what are everyone's thoughts?
    Oh, 1992 535 manual
    USA
    you test the coolant temp sensors?
    PA
    temp sensors and then idle valve
  1. Replies: 2
    Last Post: 10-09-2006, 08:38 AM
  2. 525tds se idle too fast help please
    By billzgolf in forum 5 Series BMW
    Last Post: 04-27-2006, 08:06 AM
  3. Help with Fast Idle
    By hlenoble in forum 5 Series BMW
    Last Post: 08-22-2005, 10:25 PM
  4. 525 TDS - idle lumpy when warm/hot
    By Nickhlx in forum 5 Series BMW
    Last Post: 04-16-2005, 02:51 PM
  5. Long cranking when engine is warm (M20)
    By Dan in NZ in forum 5 Series BMW
    Last Post: 06-05-2004, 09:15 AM
