Results 1 to 5 of 5
Thread: BMW E34 - 530i - Passenger Window
    Aug 2006
    California, USA
    Default BMW E34 - 530i - Passenger Window
    Guys- My car is a 95 530i, E34, with 77,500 miles on it.
    The driver window, the two rear-seat windows, and the moon-roof all function normally. The front-passenger-side window does not go up or down. It doesn't seem like it is mechanically impeded (ie, bent frame, etc.), and it doesn't sound like it is trying to go down.
    The only thing that happens when I press the window button in the center console is that I can hear a clicking coming from behind the drivers seat. The clicking is coming from the RM Module (61.35-1.379 741). When I remove that module none of the windows work and the clicking ceases.
    Question, should I try replacing the RM Module? (going to be just under $60 shipped). Is there a specific fuse for each window (ie. one that could be burned out for the front window and not the others - if so, where would I find it? (its not behind the drivers seat, and its not in th engine compartment). Or, does it sound more like part of the electrical connection between the RM module and the window itself?
    Thanks guys,
    Robert
    The GM should be o.k., but it will automatically switch of (that click only) if the power cosumption of the GM and RM will exceed 35A (pls correct me if wrong).
    So something is drawing too much power inside the door in my opinion. Maybe just 1 of the 2 small and cheap sliders.
    Remove the door panel and check all items.
    Where all the fuses are you can find online here with the words online wiring diagrams. Search engine.
    Victoria, Australia
    If you still have it all together, hold down the button, and hit the door along the bottom, this fixed my rear windows after experiencing the same problem. It occurs again if I don't use them for a while.
    Old car: 95 525i, OB/Silver, Eibachs, Style 66, Missed dearly!!
    VIN Decoder | Online ETK
    | E34 Bible
    Yes, the Fonzarelli fix.
    Dec 2006
    Melbourne, Australia
    It works, when I first got my E34 my back windows wouldn't roll down most of the time. You could hear the motor try and then give up. Slamming the door while having the switch pressed for the window to go down did the trick.
    Funny thing is, I have done this a few times and now my windows never get stuck, which is a good thing cos I would much prefer not to slam my doors all the time.
  1. Passenger side window rolls the seal
    Last Post: 07-25-2007, 12:01 PM
  2. Regluing the passenger window
    Last Post: 06-01-2007, 06:24 AM
  3. Passenger window off track
    By GregW in forum 5 Series BMW
    Last Post: 12-18-2006, 02:01 AM
  4. passenger side window slipping
    By bimmer95 in forum 5 Series BMW
    Last Post: 08-28-2006, 03:35 PM
  5. rear passenger door window shattered
    By bbig119 in forum 5 Series BMW
    Last Post: 07-05-2006, 07:30 AM
