Originally Posted by
Kalevera
Uh, again, until you figure out the exact production date of the donor car and what system the car the seats were sourced from uses, I don't think you'll get an answer. The cutoff date for the early system is 3/93.
If you have the late system, memory on the seat typically works fine without the column or mirrors in place. Sometimes it gets messed up and has to be reset. Fairly simple.
The late system's body harness is the exact same as any non-memory car. The memory harness has about 7 connectors for the memory control module and seat, and unless those are plugged in, nothing -- not even seat movement -- will work.
