Ok, after some research and looking at post I am a bit confused on the susp leveling error I'm getting... It comes pretty intermittent, might drive for 5 minutes before it comes on and might be 5 seconds...
Anyway, here is what I'm confused about.... There is a switch in the rear that senses the ride height... If you go over a bump or corner hard to the left or right this switch will detect a change in ride height... at what point, what computer decides what is and isn't an error? If it is comparing a resistor value in the CCM module, then wouldn't it trip it everytime the switch is moved? So what would keep the system from constantly tripping everytime someone climbs in and out of the car or you hit a big bump?
I looked up the schematic pinout onthe CCM module and it references a single input from the rear camber, is that the switch? and with one input, I'm really confused how this all trips...
More importantly, how do you "Disable" this error? If the input to the CCM marked rear camber is the correct input, couldn't I just either lift the input leg to the resistor and shunt either a ground or 12V to simulate a "good" signal and it should never trip again?
Input?
