:dance: I'm in the process of that "To Do" list for things I need to do to my car for this year. Actually it seems like a wish list, but some of those things are things I need to do. Anybody have those kind of things they need to do to their car? I have a little sample if you are interested...
-Replace Heater Core
-Replace Tires
-Replace Thrust Arms
-Replace Output Shaft Seal (Warranty)
-Get Mounting Bracket for CD player
-Replace Shocks for Hood
-Find Rattle in Rear. (Something Plastic... Driving me NUTS!)
-Flush Brake Lines and Replace Lines With Stainless Steel Brake Lines!
-Replace Bulbs Behind Temp. Selectors.
-Fix Lose Wire to OBC.
-Fix Rear Driver's Side Window. (Needs to go up and down, broken part)
-Replace Rubber Gaskets on Master Brake Cylinder (Upper intake)
-Fix Power Steering leak (Probably Hose)
Then...
-Get Sachs Kit.
-Get Engine and Transmission Performance Chips.
-Get Strut Braces.
-Get an Aftermarket Sub and Amp.
-Upgrade Brake Discs.
-Aftermarket Exhaust System.
-Repaint
Then...
-Supercharger
-NOS
-Twin Turbo Chargers
-Innercooler
-Lasers
-GPS & Nav. Systems
-Tub Kit
-Drag Bar
-Playboy Model For Photo Opts.
-More Lasers...
-Blinking Lights In Front Like Night Rider's Car...
-Smart Computer with Animated Voice Coming From Ash Tray
-Lighted Ground Effects
-Parachute in Trunk
-Seat Massagers with Optional Heat Settings.
-Fuzzy Dice (Blue to match my car)
-Neon License Plate Holder
-Lighted Shifter
-Huge Aluminum Rear Wing
-Even More Lasers...
-James Bond Oil Slick System
-James Bond Rockets
-James Bond "Laser" (Is that too many lasers?)
-Water Wings for swimming.
-Fancy Racing Shoes
-Fancy Racing Pants
-Auto Drive Option (in case I get sleepy)
-Fax Machine
-Copier
-Big Mac Sandwich
-Fuzzy Dice that you can hang on those hooks in the back seat, both sides!
... I think that's about all, maybe I need more lasers?
-Eric
