Results 1 to 10 of 11
Thread: Should I do a computer reset?
    New Jersey
    Default Should I do a computer reset?
    Should the battery be disconnected to reset the engine management computer as a matter of course when putting in new spark plugs and/or ignition components?
    I went to replace my spark plugs a couple weeks ago after 40k or so miles...
    3 spark plug wells were filled with oil so I replaced the valve cover gasket first, cleaned out as much oil as I could before removing sparkplugs, (some oil still went into cylinders as it smoked like a bitch after starting) and replaced 3 spark plug connector boots that had been soaked in oil for I don't know how long. I also replaced the air filter. Coils were all replaced before the last set of plugs. Old plugs were Bosch, new ones NGK.
    Instead of getting better gas mileage, it was worse. The engine also seemed to run a little rough and sluggish intermittantly. Sort of like a coil was weak or a plug not firing 100%
    ON my daily commute, I drive 70 miles each way, 50 miles at 80 mph. I kept a close watch on my gas consumption via OBC. Right after changing everything I got around 21.5 mpg at 80mph. (cruise control on).
    Gradually over the last 2 weeks (1,500 miles) it has improved, yesterday I got 24.5 mpg and the roughness and sluggishness is all but gone.
    Should I have reset the computer? Has it been trying to re-adapt to the new parts from where ever it was with the old plugs? They were pretty badly gapped but clean.
    Should I still reset the computer and start fresh? Or let it go since it seems to have improved.
    Any opinions, speculations or advice welcome.
    Thanks.
    concidering that you cant really hurt anything I wouldnt hesitate in resetting it.
    Dec 2006
    North Tonawanda, NY
    um, okay , silly question...
    how do I reset my OBC and what all gets reset?
    A fresh start seems in order.
    six forward speeds
    lol... there are 2 ways of rebotting the computer. 1st is you gan remove the batt cables, connect them together and turn the key to the run position for 15-20 minutes, this will drain the capacitors and you will need to re-enter the radio code. The 2nd way you just purr the bulkhead connector on the DME for 5-10 minutes, plug it back in and your good to go.
    Quote Originally Posted by BuckNaked
    or search "reboot"
    Benneton (United Colors of)
    if you reboot it now, you will be back to square 1, back to bad gas mileage and rough running.
    it's like a magic pill on my car.
    May 2006
    Antwerp, Belgium
    When I had my alternator swapped I think my mechanic did the same.
    By the time I left the shop my idle was like never before, but it got back to where it is now (louqy) pretty fast.
    I'm wondering if doing it again is in order and also why after a reboot all goes well and then gradually gets worse again.
    I'd assume the problem with my idle to be electrical and not mechanical.
    2008 audi A3 1.9tdi
    (former 1991 520i LPG)
    New Jersey
    Thanks for the replies, I'm due for inspection next month. If it fails for emissions I'll put the stock chip back in and reboot to get it through. Last time it was just over on one of the parameters but it was right before I put new sparkplugs in 2 years ago.
    For now, I'll leave it since it is running great finally, I should have done a reboot when I first changed everything.
    When I've rebooted in the past (last time 6 months ago with the new battery) I never had as poor performance as I had with this "tune-up" it just took a little while to reach optimum performance.
    Right now it's back to it's normal smooth self, so I think I'll leave it be. My average combined mpg is 23.5 so I think it's about as good as it's going to get.
    USA
    if your idle goes downhill after running like a dream, your O2 sensor or MAF sensor needs replacing.
  1. Replies: 19
    Last Post: 10-01-2007, 03:08 AM
  2. Shogun Reset vs disconnect ZIF connector from Computer
    By mholbrook in forum 5 Series BMW
    Last Post: 05-26-2006, 10:11 AM
  3. Replies: 30
    Last Post: 04-02-2005, 11:56 PM
  4. OT: How do you reset computer on OBDII cars?
    By Anton CH. in forum 5 Series BMW
    Last Post: 05-05-2004, 06:38 PM
  5. Did the "shogun" computer reset.
    Last Post: 05-02-2004, 10:58 AM
