Thats too bad, but at least you're not selling her.Originally Posted by Nick.Hay
Fresh oil = Yes
As well, add some fuel stabilizer to the tank, get a trickle charger for the battery as your trips around the block won't quite do the trick. I take mine off the road and never have an issue with door seals (I'm in a cold climate), but I'm sure theres something you can coat them with. Electrical should be fine if you're leaving it a dry environment. However, keep an eye out for rodent activity, they're likely your greatest threat to electrical. Also, give the tires and extra ~5 psi and keep em round so not to develop flat spots. Your trips around the block will have you believing your suspension is shot Oh wax it as well, I never do, but more dedicated folks do.
Most importantly, tinker with it if you have the space and time
Dave
