Results 1 to 2 of 2
Thread: Need wiring orientation on heater water valve solenoid
    Jan 2007
    Dayton Ohio
    Default Need wiring orientation on heater water valve solenoid
    The PO has broken the wiring connector (plug) on the solenoid and I am trying to troubleshoot it. I have three wires but they are hobbled onto the solenoid and may be out of order. Can anyone give me the proper orientation. The three wires are yellow/purple, yellow/green and yellow/brown. Does anyone know what each wire is connected to in the circuit?
    baton rouge, loserana
    the yellow/brown is probably the ground which is the center of the three pins, the other two could be figured out trial and error playing with the left and right temp controls
  1. E34 Heater valve / aux water pump cycling ??
    By Super90 in forum 5 Series BMW
    Last Post: 12-22-2007, 04:53 PM
  2. Replies: 10
    Last Post: 12-10-2006, 04:24 PM
  3. heater valve/auxiliary water pump hoses?
    By bullitt in forum 5 Series BMW
    Last Post: 04-20-2006, 10:28 PM
  4. Anyone have cover over heater/water valve?
    Last Post: 06-16-2004, 08:27 AM
  5. Valve Wear and Spring Orientation
    By Hector in forum 5 Series BMW
    Last Post: 03-25-2004, 04:19 PM
