Results 1 to 3 of 3
Thread: Wheel Bearing
    Feb 2007
    Default Wheel Bearing
    I have a 1996 528i and I believe that the left rear wheel bearing is out. When you drive it you hear a faint whine in the rear to the left. Now I heard that you cant just change the bearing that you have to change the whole hub. I dont know if this is true or not. I was just wondering if i could change just the bearing in the rear or not. Or if there is any different things that I should know about. Thanks
    USA
    in the front you have to replace the hub
    in the rear you should be able to change just the bearing.
    USA
  1. Wheel bearing/hub
    By paboone in forum 5 Series BMW
    Last Post: 09-19-2008, 01:13 AM
  2. Replies: 2
    Last Post: 06-11-2007, 12:00 PM
  3. wheel bearing hub
    Last Post: 02-04-2007, 02:14 PM
  4. Replies: 1
    Last Post: 03-12-2005, 06:40 PM
  5. oh oh, I think I've killed a wheel bearing
    By Kamil in forum 5 Series BMW
    Last Post: 11-24-2004, 01:28 AM
