Results 1 to 5 of 5
Thread: Abs Warning light?
    Feb 2007
    brooklyn
    Default Abs Warning light?
    My abs light comes on mabey 5 minutes after i start driving and i know it is not just a dummy light because last week it snowed and i didn't have abs what shuld i check?
    Jul 2005
    Belgrade, Serbia
    Default Maybe braking discs or pads?
    My ABS light suprised me few days ago, but it only was lit for a second.
    My rear discs are so thin that I thought that the problem was there, but am I right? Can it be that ABS light went ON because of warn brake discs?
    BAKSA
    BMW 520i, M50 24V
    1992, A/C, ABS, leather,M-aerodynamic pack,165000 km
    If the car voltage drops you can get ABS light triggers.
    Check your voltage (a special function in the OBC can report on voltage), it could eb a batter, alternator or something simpler..
    In order of likelihood: (IMHO of course. YMMV)
    ABS Controller: Confirmed by shorter and shorter time to make the light come on. Eventually it will come on right away. Known fault with controller circuit. Fix: reman unit (you can take it off, send it out, and it won't affect your brakes since your abs is already out) another name besides BBA is Module Master. You don't need to clear the code when it's replaced, the light will just go out.
    Wheel Speed Sensor: they do go bad sometimes. If you can, get yours tested before you replace because they're not cheap for what they are (basically a magnet on a wire). If it's the right rear- the speedometer will usually be non-functional.
    Voltage: Usually, you will get other messages like Trans Prog when this is the issue.
    o/______\o
    (Oo=00=oO)
  1. abs warning light, pad wear light
    By Lordsneldon in forum 5 Series BMW
    Last Post: 05-26-2008, 06:33 PM
  2. Warning light
    By 2fast in forum 5 Series BMW
    Last Post: 01-05-2007, 05:24 AM
  3. Wash car = SRS Warning Light
    By JScritch in forum 5 Series BMW
    Last Post: 04-04-2006, 10:30 AM
  4. air Bag warning light lighted up
    By albundy in forum 5 Series BMW
    Last Post: 02-15-2006, 03:29 PM
  5. Oil warning light
    By Gungadan in forum 5 Series BMW
    Last Post: 06-19-2004, 07:28 PM
