Results 1 to 3 of 3
Thread: The 5 min. headrest fix
    Default The 5 min. headrest fix
    I found what I think is the easiest fix for the seat cable problems. Here is how I fixed the headrest:
    I took off the rear of the seat and used a razor blade to make a cut all around the cable. I chose to make the cut as close as possible to the motor since I would be needing to pull out the metal cable afterwards.
    I made a 2nd cut about 1/2" away from the first cut and unpeeled the cut area exposing a 1/2" space of metal cable covered in grease. I slid the 2 cables towards each other and held them with my hande while I tried the seat control. The headrest started moving up & down so it was fixed.
    I pulled the metal cable out entirly and slid it through a piece of heat shrink tubing about 4" long and slid the other half of the heat shrink tubing over the other end of the plastic cable and slid the 2 plastic cables together again and used a lighter to tighten the heat shrink connector and it was done.
    Now the cut in the plastic cable will stay together.
    The fix was less than 5 mins, applying the heatshrink tubing was another 5 minutes, but be sure to use a paper towel with alcohol to wipe down the area where the cuts were made otherwise the grease will prevent tape or heatshrink from holding firmy. I also used a zip tie to align the cable in such a way that there was less pull on the repair when the motor is activated.
    I am going to use this method to fix another cable that raises and lowers my seat. I will have to tilt the seat back for the repair but the beauty is that you don't need to disassemble the motors or use any tools other than a razor blade, a lighter, & heatshrink.
    Hth's
    Fred in Houston
    94" E34 540ia
    86" E28 535i
    83" E28 533i
    Nov 2006
    Mid-Atlantic, USA
    I prefer the 5mm of coat-hanger wire dropped in the motor. Less invasive, works forever. Just my opinion in dealing with this issue for over twenty years (yeah, the E28s had the same problem).
  1. front headrest fix
    Last Post: 10-15-2008, 01:35 AM
  2. Fixed the headrest
    By ilya in forum 5 Series BMW
    Last Post: 08-30-2005, 05:11 PM
  3. help with headrest fix
    By gsotis in forum 5 Series BMW
    Last Post: 09-26-2004, 08:44 AM
  4. headrest fix
    By iliveinabox in forum 5 Series BMW
    Last Post: 05-24-2004, 05:36 AM
