Results 1 to 4 of 4
Thread: Stuck swaybar links
    Aug 2006
    Boulder, CO, USA
    Default Stuck swaybar links
    Tried replacing my ancient swaybar links today and came up with some problems. Even after covering them in PB blaster overnight they will not move even with 100+ ft-lbs of force. The bolts look to be rust damaged and softened somehow. I'm considering using an impact or a torch (at least on the lower bolts) Any suggestions on this one?
    If heating doesn't work, you might have to grind them off.
    Quote Originally Posted by Felixdacat
    That's what I did on the passenger's side top bolt 3 months ago. Cut it off, you're not reusing it anyway...
    Jeff
    I prefer to be misunderstood rather than having to explain myself all the time...
    USA
    i had to use the grinder on mine.
  1. swaybar links or dogbones hole is too small
    Last Post: 04-01-2010, 07:59 PM
  2. question about after market rear swaybar and links etc
    Last Post: 04-22-2009, 11:19 AM
  3. I'm installing some new "heavy duty" swaybar links
    Last Post: 04-06-2006, 03:57 PM
  4. Aftermarket heavy duty swaybar links
    Last Post: 11-06-2005, 08:04 PM
  5. Replaced front swaybar and front swaybar links
    Last Post: 03-14-2005, 09:16 AM
