Results 1 to 4 of 4
Thread: Oetiker clamps + CV boots = grrr
    Default Oetiker clamps + CV boots = grrr
    #$%@&! clamps! Does anyone have a solution for these things (otherwise known as a single ear clamp)?
    Here's the problem - doing a CV joint rebuild on the project car. The CV kit comes with a Oetiker clamp for the inner part of the boot where it touches the shaft.
    If I try to put the clamp over the boot and slide the boot on - it won't fit. Too tight.
    If I slide the clamp on in advance and then put on the boot, I can't get the clamp over the boot without opening it. If I open the clamp to get it over the boot, then I can't get it re-hooked to crimp it shut.
    Grrr.
    Is there a trick I am missing? What's a good clamping solution for these things short of a cheesy hose clamp?
    thx!
    Jeff
    Bellevue WA
    86 Porsche 951 - Track Toy
    near Portsmouth, England
    Cable ties work really well, Use a pair of side cutters to "walk" the tie up really tight before you cut the end off.
    All the best
    Bob
    Honolulu
    Default Make a tool
    out of a cheap pair of needle nose pliers.
    dremel a tooth to fit the clamp on the tips then bend them inward like a claw.
    or if your clamps don't have a hole or dimple to grab, then place them on and use a hose clamp to compress them until they engage.
    Lincoln, NE
    They make a special tool for crimping these clamps. I picked one up, I think just at Sears, maybe at Autozone or something. With that tool, I found that I could 'afford' to spread the actual 'clamp' section out slightly with some needle-nose pliers, allowing me just enough size to get everything assembled, and then still get a good crimp with the special tool.
    Yes, on a PS rack I've used nice big zip ties to good effect. A CV would make me a little more nervous, but I suppose as long as it's a good-quality tie...
  1. fender bender grrr..
    By bmwrp8 in forum 5 Series BMW
    Last Post: 07-13-2008, 04:39 AM
  2. exhaust clamps
    By Fraz06 in forum 5 Series BMW
    Last Post: 10-22-2006, 07:55 PM
  3. Replies: 17
    Last Post: 05-15-2006, 02:55 PM
  4. Replies: 20
    Last Post: 03-12-2006, 02:13 AM
  5. bmw crimp-on clamps ??
    Last Post: 07-07-2005, 07:28 PM
