Thread: 1990 535i trans problem
    Jun 2006
    green bay wi
    Default 1990 535i trans problem
    this / is more toward winfred...i have a 1990 535i that i redid per your forum from before when i put it back together i did the hard start to clear the computers , then all it does in the "e" mode is saty in 1 gear , if i switch it to "m" mode i can up and downshift with the shifter , is is a computer failure where i need to replace the tcm?
    thanks in advance slup
    Do you see in the cluster the gear and mode indicated?
    Jun 2006
    green bay wi
    i gues what do you mean by cluster and mode?
    a cluster is this
    And there is the gear indication like D-1-2-3....
    and the mode is then E-M-S or E-M, which you can select with the small switch to the right of the gear lever.
    If that is not indicated in the cluster, then your system is confused and you have to clean the gear selector switch and the S-E-M switch or whatever your switch has.
    Jun 2006
    green bay wi
    a cluster is this
    no that is good 2 go it lights up right on everything
    Jun 2006
    green bay wi
    bump^ any help @ all on this PLEASE
  1. 535i Auto 1990 - Strange MPG Guage / Trans Issue.
    Last Post: 09-07-2009, 06:35 PM
  2. New Guy 1990 535i
    By 535ibimmer in forum 5 Series BMW
    Last Post: 07-26-2006, 07:49 PM
  3. What is THe Best Oil For 535i 1990
    By eagle_eye2k2 in forum 5 Series BMW
    Last Post: 09-23-2005, 07:34 AM
  4. 1990 535i M alternator
    By kiNGMak in forum 5 Series BMW
    Last Post: 01-12-2005, 03:35 PM
  5. E34 1990 Jerking Problem
    By sputnikman in forum 5 Series BMW
    Last Post: 08-26-2004, 11:13 PM
