It is Meyle, so go for it.
Compare prices here
http://www.autohausaz.com/
Is this a good price for upper and lower thrusts?
http://cgi.ebay.com/ebaymotors/BMW-C...82630389QQrdZ1
I need new ones seems good?
Pat
and shipping seems high for 8 lbs.
I picked up a pair of lemforders from BMA with 750 bushings for @ $200
LEMFOERDER BMW017988 Front Control Arm
lower Leftball Joint Faces Up**steel**
control Arm,fr. 88.00
LEMFOERDER BMW017989 Front Control Arm
lower Rightball Joint Faces Up**steel**
LEMFOERDER BMW018287 Tie Rod
left & Rightw/ Ball Joints
tie Rod, Outer 112.54
Warehouse:
LEMFORDER 31121141097KIT E34 Lemforder Thrust Arms W/750i Bushings Pressed In. 105.00
LEMFORDER 31121141098KIT E34 Lemforder Thrust Arms W/750i Bushings Pressed In 105.00
Core Charges: 0.00
Discount (specE30): 24.93 (check out the new discount code)
Subtotal: 473.61
Shipping - (UPS Ground Residential): 0.00
Total Weight ( 22.71 pounds ):
Tax: 0.00 0.00
Order Total: 473.61
specE30Originally Posted by shogun
So good or bad lol. I think 200 vs 600 I know there not lemferder but...... lol
Shogun, your the master round here... Should I, yes or no
Pat
Oh ya, the price for the bma ones, is that all 4 or 2? I guess I can go check...
if you gonna tear into the frontend, for a $100 or so differance you might as well throw in the best parts, so you don't need to do it again.
BMA charged $105 for each upper arm, and $88 for each lower.
with tierods came to $473
