1 - Read tag attached to Diff - check BMWE34.net
2 - Lift rear end. Spin wheel. If other wheel turns opposite direction, its an open diff.
I can't read the tag on the side of the differential so is there a way to verify that's its "Open" or "LSD"
1992 525i Touring M50 5spd Manual 230k+ miles - SOLD:-(
couple of ways.
-lift one rear wheel up. gearbox in neutral. try to spin the wheel, if you can do it, it's open, if you can't or it goes hard, it's lsd.
-lift both wheels up. gearbox in neutral. turn one wheel. if the other one is spinning in the opposite direction, OPEN diff, if it goes in the same direction, LSD.
-try to make donuts.
drop the clutch and count the lines..
You can also easily remove the tag, clean it up & read it. Thats what I did last week on our 95 Touring. Turns out its got an open 4.27 diff. Since the car has the ASC&T it's a non issue as that seems to work better on ice & snow then the limited slip in my 535i.
90 535im
02 R1100S, 87 R100S
76 R90/S,73 R75/5
Alfa Romeos- 65 Giulia Spider Veloce
& 66 Duetto 1600 Spider
LSD - Thanks everyone
Pull a wheelie, if it tracks straight its LSD if you hit the guardrail its non LSD.
