Bad subframe bushings?
Yesterday I replaced whole clutch set with new one and I thought that I solved problem but it's still there, only less noticable.
Problem is that in low speed, in second or third gear (most noticable), when I suddenly release gas pedal, car jumps a bit forward-backward on the move, and when I hit gas pedal after that it jumps again and I hear a knock on the back of the car floor. I also changed rubber part which was near to brake, it was damaged.
What else should I consider to solve this?
Car is manual M50 520i.
BAKSA
BMW 520i, M50 24V
1992, A/C, ABS, leather,M-aerodynamic pack,165000 km
1997 535i V8
ditto on the bushings. Mine are due for replacement and I get the 1st and 2nd gear stumble a lot.
2008 audi A3 1.9tdi
(former 1991 520i LPG)
