Results 1 to 8 of 8
Thread: Intermittant TRANS PROGRAM code
    Nov 2006
    Atlanta
    Default Intermittant TRANS PROGRAM code
    Got the Trans Program error this morning. The beast sorta chugged like water was in the fuel line, then the error message popped up. Chugged two or three times then ran normal. Was only a mile from home so I turned around and took the Benz.
    Ran codes with the Peake Tool. Nothing came up.
    Started the beast again and ran it all day without any codes or problems.
    Is is possible to have an intermittant Trans Program Error? Had the Tranny serviced two years ago. Gonna call to see if I can get it done sometime soon.
    What other symptoms did the car have if any?
    I had almost the same experience a few days ago. There are alot of things to check before taking to someone.
    95 530I, 1975 C-172M
    Nov 2006
    Atlanta
    Quote Originally Posted by av8r
    No other symptoms.
    Going to drive it to work tomorrow. Got my fingers crossed
    Check the battery voltage.
    Too low voltage can also cause such problem.
    Nov 2006
    Atlanta
    Default Possible source of problem
    Well, recently I removed the MAF and cleaned it out real good.
    Upon reconnecting the MAF, the beast wouldn't start... Finally after cranking the heck-fire out of the engine, it sputtered, started, then ran normally.
    I'm wondering if this drained my battery down some. Plus I read over in the Bently forum that when the MAF is disconnected the TRANS PROG appears.
    http://tech.bentleypublishers.com/th...ID=27137#27137
    WTF?
    I have run the car with the MAF disconnected and never got the error.
    do you have bently manual for your car?
    If you do check the battery for charge.
    Quote Originally Posted by semiretired
    The trans control module may have aging/failing solder joints. I know some have successfully resoldered theirs. The other thing is the serial connector to the trans maybe slightly corroded...di-electric grease is your friend on these and other cars. Lasty, these cars and others don't like low voltage...many bogus failures/codes will show up. Check the batt voltage, and make sure your alternator is kicking proper EMF. On old cars, a bad ground can be a culprit as well.
    HTH,
    George
    Aug 2004
    West Chester, PA
    You may want to unsnap the black plastic cover (box) on the pass. fender well and check the "fuse" (link) that the + battery cable runs to. These seem to develop hairline cracks (causing intermittant probs.) before they finally break all the way through. (Unbolt the link and look at it closely). I made a new one from thick copper.
  1. '93 525iT getting trans program now, throwing TPS code
    By bimmerd00d in forum 5 Series BMW
    Last Post: 11-21-2010, 12:22 PM
  2. Trans Program fault code reader info
    By KurtM in forum 5 Series BMW
    Last Post: 05-20-2007, 08:41 PM
  3. Trans position indicator intermittant
    By av8r in forum 5 Series BMW
    Last Post: 08-27-2006, 08:33 PM
  4. it finally happened: TRANS PROGRAM (code 100)
    By shragon in forum 5 Series BMW
    Last Post: 12-11-2005, 11:58 AM
  5. Trans-program code no panic-Not yet!
    Last Post: 11-25-2005, 01:03 PM
