Results 1 to 8 of 8
Thread: engine idle
    Feb 2007
    Default engine idle
    hi i have a 1991 520i when i remove the oil filler cap with the engine running the revs drop is this normal????
    stuart
    Derbyshire, UK
    It's normal.
    1997 535i V8
    perfectly normal and showing you that there arent any major gasket leaks.
    Feb 2007
    New Forest, ,UK,
    Correct, but I assume you did it" because it was there"! Emission control gear causes that,ties up with another thread about cleaning emission parts.Do not take off brake to servo pipe as it will cause engine to run very lean,If you have old-fashioned stuff called REDEX (ask your father) then simply pour it into the intake,pause , and rev the nuts off the engine, all the crap on your valves and intake butterfly will go through the engine thoughly pissing off the neighbours but cleaning out the engine.
    Jul 2005
    Belgrade, Serbia
    Quote Originally Posted by stu412t
    stuart
    And what if revs do not drop and engine works the same with or without filler cap?
    BAKSA
    BMW 520i, M50 24V
    1992, A/C, ABS, leather,M-aerodynamic pack,165000 km
    Derbyshire, UK
    Quote Originally Posted by baksa
    Put your hand over the filler hole. Does the engine try to suck it in? If not, you could have a vacuum leak in the intake.
    1997 535i V8
    Jul 2005
    Belgrade, Serbia
    Quote Originally Posted by DaveVoorhis
    OK, I'll try that, because my M50 engine sounds and revs the same with and without cap.
    BAKSA
    BMW 520i, M50 24V
    Feb 2007
    New Forest, ,UK,
    Dead right,if revs do not alter you have probably got a blocked pipe or manifold leak,is mpg ok? Not sure about your rules reference Emissions but you will not pass a roadside check like that,for manifold leak, do the "easy staRT" spray trick,if revs go up theres your problem if not its the pipework.
  1. engine noise at idle
    By infurno in forum 5 Series BMW
    Last Post: 05-22-2008, 09:48 PM
  2. Should 540 have any engine shake at idle ?
    By pheno in forum 5 Series BMW
    Last Post: 06-07-2007, 09:14 AM
  3. check engine at idle
    By wang540 in forum 5 Series BMW
    Last Post: 11-21-2006, 06:22 PM
  4. "Check Engine" rough idle after engine Shampoo??
    By Guelphguy in forum 5 Series BMW
    Last Post: 04-27-2006, 01:06 PM
  5. E34 M60 (V8) engine idle query
    By pingu in forum 5 Series BMW
    Last Post: 03-25-2006, 07:46 AM
