Bent rim?
Hey Guys, I have a bit of an annoying problem with the front passenger side wheel, it always goes flat when its on the car, so i checked the valve and thats ok so i decided to inflate it to the recomended 31 psi and left it off the car for a week, it stayed inflated at 31 psi, so decided to put it back on the car, so i took the spare wheel off and put the original wheel back on, left it a few days and it started losing pressure again went to 20 psi . It is a new tubeless tire on the wheel, any idea's ? or suggestions ?
guys
Fraser
Bent rim?
Put it on the rear. Your front wheels should be fine then![]()
I second the bent rim. I have the same problem with the rims on mine, except it takes about 5 minutes to deflate.
Eric Claussen
La Habra, CA
1993 525i 5 speed
Corrosion of the laquer where the tyre bead sits can also cause this problemOriginally Posted by Fraz06
Smoking a Ricer in a car that cost less than his alloys. . . Priceless. For everything else, theres Mastercard![]()
get the beads re sealed with some bead sealer
