Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
Thread: Battery drain mistery? Alternator?
  1. #21
    USA
    throw the batt on a trickle charger overnight.
  2. #22
    Default Thanks again
    Ok, my battery is charging at 2A overnight.
    You said that car should run after negative battery wire is disconected so would that mean that my battery isolator switches are failing ir mine dies? If so where do I look for them?
    Quote Originally Posted by BillionPa
  3. #23
    USA
    you do NOT have isolator switches, thats an aftermarket racing product. its designed so you can take the battery out of the charge system right after starting so you have more horsepower.
    the transistorized electronics in the alternator should be able to keep up with the current drop from removing the battery from the system, as they are easily able to keep up when you turn off the low beams!
    double check the electrical grounds in the engine bay, and make sure the bolt a the B+ junction box is tight and there is no corrosion down there.
  4. #24
    Ground cable looks tight and no rust anywhere. Trickle charged battery is holding overnight at 12.4 -sweet. So it looks good so far with the problem fuse pulled. Thanks Billion
  1. Mysterious battery drain..
    By Bo525i in forum 5 Series BMW
    Last Post: 03-27-2008, 12:31 PM
  2. battery drain information
    Last Post: 01-28-2005, 11:07 AM
  3. Battery drain through fuse 20
    By dwlawson in forum 5 Series BMW
    Last Post: 11-28-2004, 09:24 PM
  4. 525 battery drain
    Last Post: 03-05-2004, 07:20 AM
