Bruno's site says you need visegrips to clamp the fuel line. Would regular spring clamps be strong enough?
95 540 six speed, Rondell 58 wheels, nothin else special
79 911 SC - pea soup green
In my experience, no... spring clamps are not strong enough. U don't have ANY visegrip? You can try it... with visegrip, I put a rag or any protective material around the fuel line before I clamp it down to prevent any damage to fuel line.
Maybe a really big spring clamp have enough force to crimp the fuel hose shut.
a piece of rubber 5/8 heater hose over the jaws of the vice grips or on the pads of the c clamps to cushion it so they don't cut into the fuel lines.
Originally Posted by scott540
thanks bill, C- clamps, spring clamps, pipe clamps I got . Used to have a vise grip somewhere.
Woodworker trying to work on a car.![]()
slip over the jaws on a clamp to protect delicate items.. those would work just fine on a fuel line..
pinch the lines....hmm. that would have been a nice option when I did mine a while back.![]()
Originally Posted by 632 Regal
This should do the job but make sure you elevate the back end of the car and do it with as little fuel in the tank as possible. It is going to siphon anyway but... Eau to gasolina...parfumeOriginally Posted by scott540
Rich
You don't need a clamp. Just remove the fuse for the fuel pump, crank the engine to remove the pressure from the lines (it probably won't start but if it does just let it die), then remove the clamps and pull the hose off the filter(s) and exchange for a new one. You might get a little fuel out of the filter so don't tip it until you're over a container.
Jeeves
94 540ia
I enjoyed the filters dumping their full amount down my arms while on my back the best, If some is good than more is better!
