Hi all,
Well after battling the stall and cut out problem i finally did a test of the fuel pressure. The guage bounces from 20psi to 30psi and will sometimes go to 40 psi. I tried pinching the return line by the Regulator and it just kept pulsing and then finally went to zero psi and of course stalled. It would indicate to me that it is not picking upo fuel at all times. Is there some sort of pick up screen on the pump or is it just that the pump is going south? Another test without the car running was to get 12v to fuse 23 and it would jump up then go to zero, it never held any pressure. I guess my question is should i try and look at the Pump or just replace it?
Chris
95 530i m60, 1975 cessna 172m
