Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: More issues
    Feb 2007
    ATX
    Default More issues
    This morning this peice wouldnt run correctly. It ran fine last night. It will start up and run REALLY bad and idle at 500rpms then if you give it gas it will die. WTF? When i turn off the key it says low coolant and oil sensor level, but i added some water and added some oil(which was fine already)
    Quote Originally Posted by justinp95
    I'll give you $100 for it.
    Feb 2007
    ATX
    add $2400 and you got a deal.
    Derbyshire, UK
    Ah, I see how this works. I must use ESP to determine what car you have. *Concentrating...* *Concentrating...* Ah HAH! It's a 1978 Datsun B210!
    Therefore, I suspect a carburetor problem.
    1997 535i V8
    Feb 2007
    ATX
    Ah, my mistake. On the other site it says. Its a 89' 535iM.
    Derbyshire, UK
    Its a 89' 535iM.
    Put that in your profile, please.
    1997 535i V8
    Quote Originally Posted by DaveVoorhis
    Dude.........My cousin had one of those. That thing was sweet. It was pretty quick, and it took turns like it was on rails. Had alot of carburator probs though.
    Derbyshire, UK
    Bogus warnings and bad running may be from a failing battery and/or charging system. Check it first.
    1997 535i V8
    Feb 2007
    ATX
    yea, I know it has a brand new battery but i cant drive it anywhere to get the alternator checked. I would check the engine light codes, but im under the assumption that 88-89 dont have bulbs in there for it to light up. Which makes no sense. And should the light come on whiles its running like a normal car? When i put the key in the ignition i can see the light come on, but not while running.
    Derbyshire, UK
    Which light? The Check Engine light or the charge failure light?
    1997 535i V8
  1. Replies: 16
    Last Post: 01-25-2008, 02:47 PM
  2. e34 CD changes issues
    By atomicDog in forum 5 Series BMW
    Last Post: 07-14-2006, 10:03 PM
  3. I need another 5er, which one????? Issues???
    By Messerschmitt in forum 5 Series BMW
    Last Post: 04-22-2006, 07:06 PM
  4. e30 issues
    By moots in forum 5 Series BMW
    Last Post: 12-07-2005, 02:08 AM
  5. Aux fan issues
    By Super90 in forum 5 Series BMW
    Last Post: 07-08-2004, 02:18 PM
