Results 1 to 5 of 5
Thread: If you put 5mm spacers on, are longer studs automatically needed?
    John2 Guest
    Default If you put 5mm spacers on, are longer studs automatically needed?
    I am fitting some rims and the fronts fit fine, rears fit fine when they were test fit, but once the bolts were tightened they rubbed the caliper just enough so that the rim wont spin freely. I can either put spacers on....presumably small ones...5mm...or sand the caliper down. I think the second option might be stupid?
    Anyways...if I go for the spacers, will the lugs need to be longer or can they accomodate such a small increase, I know it would be different if they were 25mm, etc.
    NJ
    Default Best to use longer bolts
    They're only $2.50/each @ Turner . For $25, I'd rather be safe than sorry.
    Quote Originally Posted by John2
    Drew Z
    Formerly 540iT/6, now . . . 3, 5, 7
    baton rouge, loserana
    only if you like the idea of a wheel falling off, it's so funny to see a brake rotor with .5-1" ground off in one spot, when we pull a wheel to service the car (it's only happened a couple times, and seen a few more through the salvage yard)
    Rick L Guest
    Default 5mm spacers are not hub centric...
    5mm spacers are not hub centric. Do you have any problems with shimmy? Only 15mm or higher have the hub centric.
    i had 5mm h&r spacers on my 1st set of e38 rims (245/50/16) the shimmy sucked ass, after dicking with it for 5-10k miles i had enough and sold em
    Quote Originally Posted by Rick L
  1. doors lock automatically?
    By DDK's 525 in forum 5 Series BMW
    Last Post: 04-10-2008, 11:20 AM
  2. longer studs
    By kofibimer in forum 5 Series BMW
    Last Post: 07-12-2006, 02:38 AM
  3. longer studs
    Last Post: 07-11-2006, 08:12 PM
  4. Replies: 4
    Last Post: 02-25-2006, 07:18 PM
  5. Blower Comes On Automatically
    By John Silver in forum 5 Series BMW
    Last Post: 07-27-2005, 04:16 AM
