My front pads were just about stuffed ('89 525i - approx 240k) so I bought a new set as well as a new sensor and spent Saturday arvo replacing the pads. I didn't have much troublealthough the rotors had a huge lip on them and need replacing
- trying to save for my wedding/honeymoon so I need the extra expense like a hole in the head. Anyway, the old sensor was connected to the outboard disk pad so I figured that the new one would go there also - wrong! with the thickness on the new pads, there wasn't enough room for the sensor as the backing plate of the pad was behind the caliper casting. The sensor must have been made of a bakelite type substance and promptly broke.
Which pad does the sensor go into? Has any other owners had the same problem? Would be grateful for a bit of advice as I should replace it soon (along with the rotors). The dash message "Brake linings" is still on - so I figure that it must be for the rear pads as the front one isn't connected and therefore can't be earthing out the circuit - so my theory goes!!
Andrew
White 1989 525i
absolutely stockers
