Results 1 to 3 of 3
Thread: Part Throttle wot surging, ABS Light...
    O.C.
    Default Part Throttle wot surging, ABS Light...
    Normal operating temp notice surging when part throttle and WOT. Now winfred explained that it may be the lazy o2's which is going to be checked today but I was also wondering who else experiences this trouble.
    Also...ABS light illuminates will driving...Cycle ignition...Light off!!!! Booooo!!!
    O.C.
    Oh yeah forgot to mention its a 325i...anyway...dont want to even try investing money into this car...Needs a lot of work.
    baton rouge, loserana
    abs light while driving that goes away when cycled is usually a sensor, the code should point to which, the common e36 abs problem is the shitty piece of tinfoil the pump uses to connect the 6 solenoids, it starts kicking up valve codes when it looses connection, i did a write up on how to fix it a while back and posted it here, if you can't find it ill try to dig it up if you want
  1. Part Throttle Misfire
    By Washburn in forum 5 Series BMW
    Last Post: 07-15-2008, 08:47 AM
  2. "Surging" while in gear + NOT applying throttle
    By ILoveMPower in forum 5 Series BMW
    Last Post: 01-20-2007, 06:54 AM
  3. Surging under full throttle
    By python1 in forum 5 Series BMW
    Last Post: 09-17-2005, 10:56 PM
  4. m30 535i Part Throttle Flat Spot
    Last Post: 07-01-2005, 01:39 PM
  5. Surging on very light throttle
    By phildg2000 in forum 5 Series BMW
    Last Post: 08-11-2004, 01:45 AM
